us
EMLID CASTER PRO
Turn base stations
into an NTRIP
network
Get a free 1-month trial
Build your own correction network
Custom domain name
yourcompany.ntrip.io
Promote your brand with a custom domain name. All Caster Pro customers get a domain name at ntrip.io.
Works with any brand of receivers
Any receiver that supports NTRIP protocol for sending or receiving corrections can be connected to the Emlid Caster.
Fully hosted and maintained by Emlid
Emlid Caster Pro is hosted on cloud infrastructure, so you don't need to administer servers or worry about installing updates. It can also handle all the required connections effortlessly. Even if you have thousands of rovers.
Take control of your mount points
Connect new bases, check which are online, rename them, and give descriptions.
Automatic nearest mount point
When you connect several base stations, an automatic nearest mount point is created. Clients will be able to connect to the closest available base station without rover reconfiguration.
You decide how to work with your clients
Instant setup for clients
New client setup takes seconds, and the connection data is easy to share.
Effortlessly manage connections
Statuses and connection logs allow you to stay in control and help your customers when they are in the field.
Set how many rovers your customers can connect simultaneously, block and unblock access.
Emlid Caster Pro Tiers
You can work
with Emlid NTRIP Caster up to 5 bases and 10 rovers for free.
Contact us for pricing if you need more connections.
20 bases
private caster
company.ntrip.io
$199 per month*
  • 1000 rovers
  • client access management
  • nearest mount point
  • custom domain
  • connection log
*billed yearly
50 bases
private caster
company.ntrip.io
$399 per month*
  • 1000 rovers
  • custom domain
  • connection log
*billed yearly
Start a 1-month
free trial
Our application engineers will contact you for more information and provide credentials for the free trial within a working day (9:00-18:00 CET).
Pre-sale support:
Toll Free: 888-454-1916
Direct Dial: +1 817 865 3334
  (ex. 101)
