REACH RS3
Data collection with centimeter
precision. Made for professionals.
$2799
BuyThe Reach RS3 is a game changer for my team. The tilt compensation allows accurate surveying of hard to reach points, and building corners and walls can now be shot directly without using offsets. I am amazed at the accuracy, even with fairly large tilts! Emlid has done it again with the RS3, leading the way in affordable, accurate and versatile GNSS survey kit.
Using the RS3 was like using the RS2s for the first time, the opportunities the tilt compensation opened up for us were fantastic. Building corners and walls are now a breeze, also for recording points that are just that bit too far under cover.
If you're in the industry, tilt compensation is something you have to try. Emlid have once again brought this feature within reach for a wide audience, I can't wait to see the creative ways people will start putting this to use on the forums or user groups.
Open-pit mine design
Reach RS2 helped our users design a gold mine pit in Alaska. The team surveyed drill collars with centimeter accuracy and exported the results to a GIS app for pit design. Then they used established base points to place GCPs for progress monitoring.
Topographic survey on the coastline
Photogrammetry for a maritime concession in Punta Arenas, Chile, was a challenging project for Kenos Drones. The team used Reach RS2 for RTK land surveying equipment at sub-zero temperatures. They lifted high and low tide lines from the coast of the Strait of Magellan.
Photogrammetry for a maritime concession in Punta Arenas, Chile, was a challenging project for Kenos Drones. The team used Reach RS2 for RTK topographic survey at sub-zero temperatures. They lifted high and low tide lines from the coast of the Strait of Magellan.
Emlid Flow is a mobile app for iOS and Android. It handles all the fieldwork—receiver settings, data collection, coding, linework, and stakeout. All survey data is in sync with the cloud-based service Emlid Flow 360, which allows you to access your projects from your browser and manage survey data and code lists.
Measure and move ahead with just a few taps. You can use either predefined geometry types or a full-blown code library, whatever suits your needs.
Add codes, quickly switch between different object codes, start new lines, and continue collecting existing ones.
Upload your custom code library or use a standard one built into Emlid Flow with more than a hundred codes available from the start.
Upload topographic maps, cadastral plans, and aerial imagery from WMS and WMTS sources or work with a built-in satellite map.
Find or adjust missing or outdated local coordinate system parameters. Depending on the data provided, Emlid Flow automatically chooses the calibration algorithm that delivers the best accuracy.
All residuals are placed on a single screen, so you have the full context while you adjust.
Work with survey plans, quickly adjust designs in the field, or simply review data for informed decision making.
Tools allow you to create new geometry directly in the app with specified distance and direction, find coordinate geometry attributes such as area, distance, direction, slope, and more.
The Emlid Flow app is synchronized with the Emlid Flow 360 service. This allows you to create and access survey projects, manage coordinate systems, and export and import data using both the mobile app and the cloud service at flow360.emlid.com.
CSV, DXF, and Shapefile
The full list of features is available with the Survey subscription.
Try it in Emlid Flow 360 for $25/month.
The basic functions are available with the Free version.
Reach RS3: RTK receiver with tilt compensation
Reach RS3 gets a fixed solution in seconds. The receiver tracks GPS/QZSS, GLONASS, BeiDou, and Galileo. Multi-feed antenna with multipath rejection offers robust performance even in harsh conditions.
Signals tracked
L1OF, L2OF, B1I, B2I, E1-B/C, E5b, L1C/A, L2C
Signals tracked
Reach RS3 provides data in standard NMEA that is used by most GIS and survey apps. Simply connect your device to Reach over Bluetooth or via cable, and turn on “Position output” in Emlid Flow.
Enjoy your work with Reach RS3 and any regular data collector. Stream NMEA data via Bluetooth.
We’ve successfully completed the tests with the leading land survey software MicroSurvey FieldGenius. Reach RS3 pairs with most types of traditional data collectors via Bluetooth or USB and feeds the coordinates to MicroSurvey FieldGenius in NMEA format. Check out our FieldGenius Setup guide to get started!
Compatible apps
ArcGIS Field Maps,
FieldGenius, and
others
You can control your Reach unit, set up a base station, log RINEX data, configure output — everything in one app.
-20 to +65 ºС
Working temperature. Isn’t afraid of either heat or cold.
All connectors are completely sealed and protected from water and dust with silicone plugs.
Up to 22 hours
Industrial LiFePO4 battery can charge over USB from a powerbank.
Polycarbonate body
Polycarbonate body
Polycarbonate, an extremely durable material used in bulletproof glass, makes Reach RS3 impact-resistant.
126 x 126 x
142 mm
Fits in a small bag.
Weighs less than
a typical survey pole.
