Performing centimeter-accurate GPS / GNSS survey in RTK: video tutorial
Meet the new format of tutorials by Emlid—educational video courses. The first video course will introduce you to the Real-Time Kinematic technique. It is intended for those who are getting started with Reach and the RTK GPS technique and want to take it up a notch. Learn how to work in RTK GPS using Reach receivers, equip with the knowledge and skills, and get the most out of your surveying equipment with our application engineer Polina! These courses will teach you to run a centimeter-accurate GPS or GNSS survey with Reach receivers.
An In-Depth Look at RTK GPS and GNSS
In the first video, we define what RTK is, show how to establish the connection between Reach RS2 and the smartphone using the Emlid Flow (ex. ReachView 3) app, and configure settings on both base and rover.
Practical Tips for Achieving Centimeter-Accurate GPS / GNSS Survey
In this video, we look at the solution statuses you have in ReachView 3, consider surveying conditions, and explain how to obtain centimeter-level accuracy in RTK.
Now that you’ve completed our video course “How to get centimeter-level accuracy in RTK,” take a short quiz to ensure you get the most out of it!
Quiz How to get cm-level accuracy in RTK
Handpicked materials
- How RTK works
- Placing the base
- What is NTRIP
- Accuracy and precision explained: surveying with high precision GPS
- GNSS vs GPS: what is the difference?
- Precise drone mapping with Emlid gear setup: GNSS base station, GCPs, and more
- Basics of RTK GPS and GNSS for non-surveyors
- Evolution of mapping: from clay tablets to GNSS receivers
