Precision agriculture technology: How a reliable GNSS receiver can help your farm
Precision is a key to efficient and balanced farming. Clever use of GNSS receivers can significantly cut costs, ease the workflow, and improve the results. Reach GNSS receivers help our users in various ways, starting from GCP placement for drone surveys to the complex integration with precision agriculture machinery. Read this article to check out what Reach can be used for when it comes to prosperous and optimized farming with precision agriculture technology.
- Drone mapping for precision agriculture
- Machinery guidance
- Autonomous navigation
- Land leveling
- Landscape architecture
- Reach receivers for precision agriculture
With a planned mission, the drone gathers accurate photos of the field with georeferencing tags. This precision agriculture technology allows farmers to obtain a complete picture of the site, including planting lines, drainage lines, and other valuable information for further analysis. By utilizing precision agriculture equipment, farmers can enhance their crop management and increase efficiency. The integration of drones and precision agriculture provides numerous benefits, such as improved data accuracy and more informed decision-making.
A typical workflow includes a drone with a camera and a GNSS module on board. Another GNSS receiver acts as a base for sending the corrections in RTK mode or record logs for further PPK. Precision agriculture technologyleverages these techniques to ensure accurate and efficient data collection. Please check our PPK mapping guide and recent video guide featuring RTK drone by DJI for more information about PPK and RTK techniques for drone mapping.
Experienced drone pilots recommend setting up ground control points (GCPs) and checkpoints on a site. They are necessary for stitching the pictures into a map more accurately, enhancing the effectiveness of precision agriculture equipment. To learn more about drone mapping, check out our page about GCPs.
One of our users in Brazil, Antonio Arns, provides his company’s customers with a complete crop monitoring plan. In the ArnsTronic case, the Reach receiver became the base for the drone. Also, the drone was equipped with the Reach module, which you now know as the improved and upgraded Reach M+/M2. The drone created a map with a precision of 4 cm and saved the company a considerable sum in fuel, labor, and maintenance costs. This real-world example highlights the benefits of precision agriculture and demonstrates how drones and precision agriculture work together to optimize farming operations.
Antonio says that with Reach equipment and a drone, he covered 150 ha in an hour. In comparison, Antonio can cover only 10 ha at the same time with a tractor. Using Reach for drone mapping a field takes less time. Read about the ArnsTronic case.
Machinery guidance
GPS guidance for heavy machinery becomes a decisive advantage for accurate spraying, fertilizing, or planting. GNSS receivers paired with a guiding app allow the machine to follow the precise route you plan for your goals. The centimeter-accurate positioning reduces overlaps and missed zones.
GPS guidance
To obtain the centimeter precision for your agricultural machine, you can use one Reach receiver mounted on the tractor and get all your corrections from the local RTK service. However, it can be costly, at around $1650 per year for subcentimeter accuracy.
Instead, you can use two Reach receivers: one mounted on a tractor and the other acting as a base. That’s how our user Joseph solved the issue with a costly agricultural RTK subscription service. Building your bundle out of the Reach base and rover for corrections can save you thousands of dollars and still provide centimeter-precision results. Read about Joseph’s case.
Auto-steering
Automated steering is also a part of machinery guidance. Visual guidance and plotting the route help reduce fertilizers’ usage and avoid overlapping of already treated land. Besides, auto-steering leaves the farmers’ hands-free during the fieldwork.
With a bundle of an RTK receiver and particular software like Cerea GPS, the machinery doesn’t need a farmer to steer. The Reach receiver sends the accurate tractor’s position to the Cerea app, and the app is then responsible for auto-steering.
Andreas Ortner used the Reach RTK kit on a farm in Austria and managed to work 50 ha of land with an auto-steering tractor. Using the visual guidance saved up to 20% on fuel and fertilizers, and the auto-steering helped do the work in less time. Read about Andreas’s case.
Autonomous navigation means that machinery can plan its path and follow the route without a human being in charge. The only thing a human needs to do is to design the initial route and provide all kinds of corrections technique-wise.
Improving the efficiency of sowing, treating the fields, and harvesting results in increased crops and reduced costs. The human factor is cut down to a minimum, and therefore, provided the machinery is appropriately equipped, the general performance is better.
A group of engineers from the University of Sydney’s Australian Centre for Field Robotics (ACFR) created an agricultural robot. It is aimed at helping countries like Samoa or Fiji to digitize and power up their farming. With the robot by their side, smallholder farmers fulfill their need for a higher turnover of crops and eliminate the human factor.
The key idea for this robot is not just to be efficient but also to be reasonably priced. Using precision agriculture equipment such as Reach RS+ for high accuracy navigation provides excellent performance and reduces the prime cost of the robot. Read about the Digital Farmhand Robot.
Land leveling
Land leveling is used to prepare the field for sowing and changing the drainage pattern. In any case, the whole idea of it is to make the area flat and even. With precision agriculture technology like GNSS coming to help agriculture, farmers can now work on water distribution and a higher crop yield.
Our user David Hofer combined Reach RS2 as a base and Reach RS+ on a vibration-damping platform mounted on the machine. The base sends dynamic corrections to the rover, controlling the tractor’s vertical position. With the help of Fieldgenius as a grade indicator, he managed to reach a centimeter-precise vertical accuracy.
Using Reach receivers for land leveling proved its efficiency and also appeared to save on the budget. David says this whole setup cost him $15,000, which is many times cheaper than other equipment with the same level of accuracy. Read about David’s case.
Every tree has its place. This is the motto of the Allesbeste avocado orchard. You can use Reach receivers for staking out the points for each tree to make sure all of them get equal amounts of sun, water, and attention from the farmers. After the whole area is mapped, Reach RS duplicates the roads and terrace rows of the trees designed in GIS software.
This is an excellent example of conscious and thorough planning of future crops. The team took all the area’s peculiarities into account and created a precisely calculated orchard. Reach RS helped locate every tree at the same distance from each other and followed the particular plan.
When the orchard is built carefully, the farmers can predict possible land issues and eliminate them. Also, it allows the estimation of crop yields more precisely. Read about the Allesbeste case.
A multi-band Reach RS3 receiver with cm-precision is an excellent fit for your farming purposes. You can order the receiver and other Emlid products in our official online store, check the list for your local dealers, or explore our website to learn more about us. If you have any questions about your workflow with Reach, please send us a message, and we’ll be happy to help you.
