Simplified access to your Reach receiver in a browser with the new Firmware 31
We have released the Reach Firmware 31 update. It simplifies access to your Reach receiver in a browser through Reach Panel. Take a closer look at the new features and give them a go.
Easily access your Reach in a browser
You can access your receiver in a browser by entering its IP address and view it through Reach Panel. This is a tool that allows you to check the state of the unit, download logs directly to your computer, and set the advanced configuration of the NMEA messages output. To do so, make sure that your Reach and mobile device/laptop are connected to the same Wi-Fi network.
Previously, to open Reach Panel, you had to check the dynamic IP of your Reach in Emlid Flow. Now, the access process is easier as you can set up a static IP address for your receiver in a particular network. Your Reach will have a unique address, and you won’t have to look it up every time you want to go to Reach Panel.
Set up a static IP for your Reach when connecting to a new Wi-Fi network. For more details, check out this tip and the detailed guide on how to access Reach Panel.
Logs in Reach Panel
