Emlid journey to simplicity: GNSS that just works
Over the last decade, Emlid has evolved from a startup serving the DIY community into a trusted, global provider of high-precision GNSS solutions. Our story began by making RTK accessible, and today, we continue that journey with a bold commitment to the philosophy of simplicity.
We believe the future of RTK GNSS isn’t about complexity—it’s about simplicity, which translates into confidence. It’s about using gear that just works, whether you’re under a dense canopy, navigating an urban canyon, or measuring a hard-to-reach point.
We are building reliable, intuitive tools for everyone, everywhere. Each detail, from the first setup to everyday workflows, is designed to support both seasoned professionals and inexperienced field teams.
Taking that philosophy further, we introduce the new generation of Emlid GNSS receivers.
The next generation of Emlid RTK GNSS
At the beginning of Emlid’s journey, we proved that centimeter-level GNSS precision could cost 10 times less than before. Now, we’re removing the next barrier to adoption: complexity.
Reach RS4 and RS4 Pro
The Reach RS4 and RS4 Pro receivers mark a major evolution from the previous Reach models. They offer uncompromised precision in any condition and quicker workflows than ever before. The Reach RS4 Pro stands out with its innovative camera-vision technology, which redefines traditional RTK and cuts down on survey time.
Key features of the Reach RS4 and RS4 Pro:
- All-band RTK reception (L1/L2/L5/L6) across all satellite systems for unparalleled performance in urban canyons, dense canopies, and other difficult conditions.
- Integrated antenna system with diversity LTE, dual-band Wi-Fi, and Bluetooth for a clean GNSS signal and stable fix solution wherever you go.
- Emlid multi-band radio system up to 2W, interoperable with third-party gear for sending and receiving corrections. The radio supports both licensed and license-free operations at 450 MHz and 915 MHz. This allows users to adapt to project needs while staying compliant with regulatory requirements.
- Next-generation IMU tilt compensation with up to 5 times faster initialization.
- Durability-first design with a magnesium alloy body, IP68 protection, and user-replaceable bumpers to secure the receiver from the scariest falls.
- Made for iPhone certification for compatibility with iOS apps, including Esri ArcGIS apps.
- Innovative quick release mount for a survey pole, ensuring accuracy and speed, even when tilted. Сompatible with standard 5/8” thread.
Vision capabilities
Building on the RS4 platform, the Reach RS4 Pro adds groundbreaking vision capabilities. With dual, factory-calibrated full HD cameras, it delivers the new features:
- AR stakeout—an intuitive, augmented-reality guidance for fast and easy navigation to the points. Any geometry from the project can be projected in AR in the Emlid Flow app.
- Measurement from images—a new solution to capture inaccessible points safely and quickly, be it on a facade or in the middle of a highway. The images taken directly from the receiver’s camera are processed in Emlid Flow to provide accurate coordinates.
With its camera capabilities, the Reach RS4 Pro goes a step further than traditional RTK. This next-generation receiver greatly speeds up stakeout and saves time for total station setup when measuring in hard-to-reach or hazardous areas.
The Reach RX2 is an ultra-portable RTK rover that is simple to use, with no settings to configure. Building on the strengths of the previous Reach RX, the new model is enhanced with greater performance in obstructed areas and new IMU tilt compensation.
The new RX2 features include:
- All-band RTK support (L1/L2/L5/L6) for greater reliability under canopy or in urban areas.
- Second-generation IMU tilt compensation for accurate, level-free measurements.
- The quick release mount for a fast and reliable setup in the field.
Pocket-sized and easy to deploy, the Reach RX2 is ideal for GIS, construction, and asset management in companies running multiple projects and teams. It integrates seamlessly with Esri ArcGIS apps for GIS data collection, and with the Pix4Dcatch app for mobile terrestrial scanning.
Designed for simplicity and scalability
Emlid receivers work straight out of the box with the ease of a consumer device while delivering the accuracy professionals expect in the field.
This simplicity doesn’t just save time—it unlocks new ways to work. Teams without a surveying background can take on field tasks with minimal training, helping companies scale faster and reduce dependency on dedicated crews.
Also, paired with the Emlid Flow app and Flow 360 cloud platform, Reach receivers offer a seamless end-to-end workflow—from data collection to final delivery. It’s a complete solution designed for the real-world demands of GIS, construction, and infrastructure teams.
“Simplicity means less friction, less uncertainty, and less wasted time. You turn it on, it just works,” says Igor Vereninov, Emlid’s CEO. And that’s not just aspirational—it’s the foundation of everything we’ve built.
The new philosophy deserves a new look
To highlight the new, bold positioning, we are refreshing Emlid’s brand identity. The redesigned logo, modern color palette, and typography signal simplicity and reliability. As a result, it’s clean, robust, and unmistakably Emlid.
Discover the new way to survey with Reach receivers
The Reach RS4, RS4 Pro, as well as RX2 are designed to make high-precision GNSS more adaptable and reliable for everyone—from individual surveyors to field teams across GIS, construction, and diverse industries needing positioning data.
Developed in the EU, these receivers are built for real-world challenges and backed by regular firmware updates and responsive customer service. Whether you’re managing a single job site or scaling operations across multiple teams, Emlid gear is designed to fit your workflow and grow with your needs.
Explore the new product line and get started with Reach RS4, RS4 Pro, or RX2.
Versatile receiver and ideal base station. Maintains precision under the canopy and in urban areas.
Powerful receiver for fast and safe surveys with AR guidance
and visual data capture.
Perfect RTK rover for teams in GIS and construction. Stays centimeter-precise even at high tilt angles.
